What plugs are safe with a 275 hit!!
Old May 9, 2009 | 04:36 PM
1badA3Z's Avatar
Thumbs up What plugs are safe with a 275 hit!!
Just making sure i have the right plugs in it to get the job done,what plugs do u pros suggest with a 275 hit!! Thanks in advance!!
Old May 9, 2009 | 05:04 PM
Braciole's Avatar
I would say a 7 minimum. Start with 8s to be safe read your plugs after every pull till you know whats going on.
What are you running?
Old May 9, 2009 | 05:11 PM
camscam02's Avatar
id start with a 9 and go from there. non projected ofcourse, cant really say though, motor cubes compression etc could change that guess.
Old May 9, 2009 | 05:13 PM
Braciole's Avatar
Check this thread
https://ls1tech.com/forums/nitrous-o...us-outlet.html
Old May 9, 2009 | 05:36 PM
Mike@HSW's Avatar
give us some more info on your motor. You really can't determine a good plug based on shot size alone.
