NANO/Stand alone - AFR
Old May 9, 2009 | 09:03 PM
GrimReaper's Avatar
Default NANO/Stand alone - AFR
10lb NX bottle and valve/4500psi Nano/Nitro Daves stand alone on the low pressure spring currently @ 8psi. Fast 90 direct port 4 solenoids(2n2o & 2fuel) done by Nitro Dave. That is just a basic overview of the system.
I was told by Nano to turn up the psi on the cell 2psi to accomidate for the added nitrous function. but i am still hitting 10.0 afr on the second half of the track. how low can i turn that low pressure spring psi to adj the afr without rejetting?
Old May 9, 2009 | 09:30 PM
WE TODD DID's Avatar
You don't have a regulator you can adjust? Sounds like you need to take that two pounds back out of it.
Old May 10, 2009 | 09:25 AM
GrimReaper's Avatar
yes i do have a regulator that i can adjust. and also i did take the 2 lbs back out. i was just curious how low i can go psi wise before i could start having issues. can i put it at 3-4lbs??
Old May 16, 2009 | 01:01 AM
I don't like getting much under 5psi. If I have to get it that low to get a good plug reading, I'll start taking some fuel jet out of it. I prefer to stay 5psi and above.
