Fuel feed for nitrous from full return fuel system??
Old May 17, 2009 | 01:54 PM
Snyper's Avatar
Default Fuel feed for nitrous from full return fuel system??
I converted my fuel system to a return style. Where would I get my fuel source for the wet kit?
Old May 17, 2009 | 02:19 PM
Robert56's Avatar
Anywhere that is easy on the pressure out side of your regulator, not the return as that is bleed off pressure/volume and won't supply correctly. I have a pretty good fuel systems mods write up you can prob find on google for some insight.
Robert
Old May 17, 2009 | 04:34 PM
Snyper's Avatar
Is there a fitting I can put inline on the pressure side?
Old May 18, 2009 | 08:59 AM
Nick@HSW's Avatar
Yes, what size feed line and what size shot are you running?
nick
Old May 18, 2009 | 10:41 AM
Chris@NitroDaves
Guest
Posts: n/a
From the pic it looks like you are using -6 fuel hose. I'd suggest keeping the -6 all the way to the noid but thats my preference. If it is then this fitting will work for you.
Earl's - 926106ERL $16.99 < dont have it in stock but we can get it >
-Chris
Old May 19, 2009 | 08:57 AM
Snyper's Avatar
150 shot. on a -6
Old May 19, 2009 | 09:52 AM
Chris@NitroDaves
Guest
Posts: n/a
I would because thats what you are already working with. If you absolutely wanted to run -4 then you could get a -6 manifold and then get a 1/8th x -4 fittings and run it from there to the solenoid.
-Chris
