cam choice
Old May 23, 2009 | 03:36 PM
pozesd99''s Avatar
how do i know what grind to get? lol
Old May 24, 2009 | 04:16 PM
pozesd99''s Avatar
bump,
Old May 24, 2009 | 09:45 PM
dnkynrbk's Avatar
Man I went with a MS3 which is alot better then the MS4. With the MS3 and patriot stage 3 heads 64 cc on a 370 fuell weight car w air. I went 11.1 na and 10.1 on a 200 shot with a 4l60E. Tranny and a not very good converter. I have since switch set ups as you see in my sig. MS3 cleanrance is fine and stock rockers are fine. You just need 650 lift springs. If you plan to drag the car alot do a custom grind cam. Cam motion did mine. There are serveral good sponsors on here. If you chose and off the shelf cam the ms3 is proven and loves spray.
Old May 24, 2009 | 09:48 PM
dnkynrbk's Avatar
need anything pm me. Ill help you.
Old May 25, 2009 | 11:26 AM
pozesd99''s Avatar
thank you, you sir have a pm
