need advice please help
Old May 22, 2009 | 06:14 PM
trw22z28's Avatar
Default need advice please help
I just bought the nxl direct port kit what i'm needing to know is what should i use to activate it should i use the micro switch or some kind of window switch what kind also what plugs should i run its a ls1 heads cam 6spd any info would be great thanks
Old May 22, 2009 | 07:41 PM
ToBiN!'s Avatar
I use a window switch in combination with a wide open throttle switch. Having these two devices together offer the best reliability and safest operation IMO.
I run TR6's. I think most boosted/Nitrous applications require the NGK TR6's gapped at .035.
Old May 23, 2009 | 09:42 PM
jeepers_88's Avatar
Id go exactally with what he said above, absolutley get a window switch with the M6 and a WOT switch is a given. I use the Microedge from Harris Speed Works, it does both functions and then some. I love it because once you program it to your liking, just flip on your arming switch and drive it like you stole it The microedge does the rest. its the best asset to my kit
