Nitrous cutting in and out.
Just installed nitrous system and only running a 50hp shot. Just to make sure everything is ok. Glad I did.
A stock fuel pump should supply enough fuel for this setup, right? The reason I am asking is the nitrous is cutting in and out, and fuel pressure is dropping. Now after letting the car sit overnight and getting some relief from my frustration I noticed that the fuel line down stream of the solenoid was a little loose, I could still tighten by hand. Now before actually spraying the nitrous I tested the system out and was smelling fuel. I shouldn't smell fuel if all of it is going into the intake correct? If not then I know I had a leak and that is probably why the fuel pressure was dropping enough to make the n2o cut in and out?
So I guess what I am asking is, am I having a pump, FPSS, or leak issue? What other tests can I do the help determine the problem?
Thanks.
But I have seen some stock pumps peter out befor others. A fuel pressure gauge is the best way to know.
Dave
Thanks.
