Cost increase from wet to DP
just figured i would stop in here and ask the gurus about it
thanks
However there are advantages to having a properly plumbed directport.
1. The ability to individually tune each cylinder.
2. The most precise even distribution to each cylinder.
3. Able to spray larger HP shots do to distribution.
There are disadvantes.
1. Cost
2. Tunning Time is longer
3. Larger strain on fuel system
With out a doubt for 250 -300 a directport is the best choice. However There are many people spraying 200 and 250 on our plates. We even have customers spraying 300.
Due to our plate design I would not hesitate to spray 200-250 hp. As you get in the higher HP range reading spark plugs is critical. By reading the spark plugs as you move up in HP levels you will have an early indication if a cylinder is burning hoter than the others.
So what My suggestion is.. If you have the money for the directport go that route. If you do nt have the funds or race a in a class that probits directports our plate will easily do what you are looking to do.
Dave
