Any advantage of plate VS nozzle?
Your not going to find a huge performance advantage. You will still have the easy of installation and cleaner look though. What your also gaining is a system with less limits. Depending on the kit you may not want to go over 125-150, whereas a plate like ours will go much further then that. So really your investing in the future if you ever plan to spray a larger shot.
Guest
Posts: n/a
-Chris
8 second mod
the plates are much nicer over all even if they dont work "better" for 100-125 shot, the nozzle was cool when thats all she wrote, but now with the plates out, would never install a single nozzle set up
I would get a newer style plate system as the others have suggested. It looks and preforms better. Plus you can spray a decent size shot down the road without having to go DP just because you want more than a 150-175rwhp and still get good distribution. Just remember, after a certain point a DP is still the way to go. PS, I know nothing, never did, never will.
