why do more prefer wet over dry??
Adding a wet kit/hit into the mix is fine, however, I always suggest doing so at a higher point in the RPM band. That way, keeping the air moving at a greater velocity will reduce fuel drop out issues. Many are in fact running the Dry hits as a 1st stage, then adding a 2nd stage of wet later in the run or higher in the RPM band. Benefits are great, no off launch lean spike, minimizes the chance of fuel drop at lower RPMs, and a great way to pull timing. For a while I had a wet nozzle kit on my Z06 as my 3rd stage. But, upon review, I couldn't find any real benefit running a wet stage, only down falls. So off it came and now 3rd stage is on my Dry plate.
Many were telling me that the 42's (Ford SVO green tops) would not support my HP levels. Below is a quote from my site, just for insight for those reading along. I didn't even hit 80% duty cycle at 644rwhp. The point I am making is that many injectors are rated at lower fuel pressures compared to what the LSx platform runs and often times we have much more capacity than we realize. That's an old Dry tuning trick, up the fuel pressure and increase the capacity of any injector we may be using. when running a custom fuel system with a regulator at the rails, we can increase the psi a few pounds and extend the useable range of the injectors. I have done this in the past in order to up the Dry HP shot with out changing the injectors out.
Robert
A window switch, fuel pressure safety switch, a wide band controller are not tricking ****. It is TELLING the NITROUS KIT what to do, TELLING it when to hit, TELLING it to shutdown in a lean cindition. Not "tricking" as you put it. Those added safety features on a wet kit have nothing to do with the injectors or pcm. Your dry kit on the other hand... aim a dry nozzle at a maf and HOPE to get the right air/fuel, and HOPE you dont run out of injector.
As far asTechnology goes, technology has come a long way with both versions of kits. Controllers have made both these kits rediculously safe and easy to use. The main and biggest problem with nitrous is not only people giving wrong advice (not aiming that at you Robert), but people half assing these kits wether it be in the wiring or the plumbing, and thats whats blowing these cars up. That and shitty, low quality noids.
Robert I stand by my Wet kit. I see your dry kit as cheap and more or less a guess on air/fuel when it comes to the average joe installing one in his garage
With all of todays cold air intakes, I dont see how you could possibly put an X on nozzle placement and it be right. Hell clocking a maf different will change a tune. Now if you want to throw a couple controllers on there at a couple hundred dollars a piece and maybe even a $500 dyno, yeah, one might go dry, but why?
Robert im not knockin you. Hell I dont even know you and I dont think I have ever talked to you, but different people will have different opinions. I can tell by your first post this is something you and me are just not going to see eye to eye on and we will have to agree to disagree.
I, along with countless others chose to go wet. You along with countless others chose to go dry. both systems have their ups and downs, and both can kill a car quicker than **** when not done right.
Nice to meet you btw
I don't totally disagree with your input, as having all the safety stuff is key to a good install; however, once both style kits have all of the goodies, things can still go wrong with the wet hit and will not effect the dry hits. I will cover this a little later in the thread when I get a chance and believe you will be surprised.
Here is my biggest complaint with your debate: You are using old out dated arguments that have no real basis in the modern dry after the MAF style kits. Once again, I do not support before the nozzle style wet or dry kits. Nozzle kits on the LSx platform is dated technology, IMO.
I think you would do much better in your debating if you had up to date information and understood how the dry technology is now being applied. The cutting edge technology has made the dry a very good option and really has nothing to do with anything you stated against the dry tech of old. Modern tech, due to the smart engineers out there, have allowed us to totally control all aspects of the dry hit with the stock PCM. Myself, I love the up to date methods and tech compared to the old school mechanically controlled wet hits.
This is exactly what this thread is all about, guys like yourself using out dated facts to still try to put the dry kits in bad light. Things have changed dramatically. try running a street/strip Dry Direct Port a year and half ago. It was very expensive and complicated and required a new PCM. Now we can do everything we need with the stock PCM. We use our injectors to fuel all performance n/a needs, as well as all turbo(s) needs and blower needs. It's really not much different than the turbos needing other than stock info and injectors to run the big HP. whens the last time someone hurt their motor from the injector(s) failing? yes it happens, but very remote indeed. So now the dry technology has come full circle and we can fuel our dry hits very easily and repeatably. there will be no variations in your a/f ratio going with the new after the MAF style kits, so your nozzle tuning argument is nulled, it just does not apply any longer.
I enjoy debating and talking tech with you, no doubt. i am glad your happy with your wet kit. My goal is not to make you switch, but rather point out the new tech that most do not realize is here. I think what happens the most is many think that I am trying a this way or no way thing. Not so, just want people to really understand that there are now very viable options to the old school style wet hits. many are comfortable with sticking with the wet, as it is easier to understand, as it has been around unchanged for 40 years. On the other hand, many of us with the LSx platform and computers really love the high tech that goes along with it, I know I do. so in conclusion, some will via for staying wet due to ease of understanding and some will go high tech dry because they are already into the high performance tuning and own HP Tuners or similar and have a wide band and etc.
Just to make sure, I know my style sometimes seems aggressive, but really I am not like that. Nothing personal and we are opening the doors for many reading along to get a better grasp on the whole nitrous experience. I have a great passion for some reason concerning nitrous, and believe this to be true due to the ever changing high tech of these cars and how dry fits into this. If I stayed with the wet kits I would have been done talking on this forum 5 years ago, as not much has changed in that regard, lol. Good day and look forward to your next post.
You see this as cheap, lol. You may change your mind once you realize what is really going here. Nozzles are dead. You based your cheap comment on something that does not apply what so ever to my system, there are no nozzles. However, I did have great success with my 4-nozzle set-up on my previous set-up. The a/f ratios no longer wander nor change at all.
Robert
but really, without alot of extra stuff your ALWAYS gonna have to spray MORE with the dry kit than you have to spray with a wet kit to make the same amout of power.
n2o jet for a wet 150 shot is ~.065
n2o jet for a dry 150 shot is what ~.100-.110?
enough said.
I think theres alot of people that dont know Robert or his past history in the nitrous world. For those of us who do, we listen to his advice.
DC, your not just tryin to tell a regular everyday member who happens to run a dry set-up he is wrong. Your tryin to tell a guy with more nitrous experience in his pinky than you have in your entire being that he is wrong & your right.
I'll say this one time & one time only. Dry kits do not only rely on the ol' spray & pray method of just placing a nozzle & hoping it's ok. Maybe they do on cheap **** kits people try to piece together. But not when people who actually know what the **** they are doin with a nitrous kit install one. So what if I need 1 $150 nitrous controller along with the standard safety features like WOT switch, FP safety switch & what not. Thats a minimal cost to never have to worry about puddling in the intake.
Let me ask you this self proclaimed nitrous guru, how many dry kits have you seen cause puddling & massive intake explosion due to a severe backfire? I'd almost bet my left nut you have never seen a single case of this happening yet you still scream wet is safer. Your logic & arguements on the subject make no sense. They are only your opinions on it & even those are wrong. Maybe you should listen to those more experienced in a certain field before you attempt to argue with them. You might actually learn something.
If your just gonna bolt on a wet kit & think it'll take care of everything for you, well there is no getting thru to you anyway, LOL. How you gonna check your A/F without at least a wideband or some tuning program? You just gonna take the nitrous manufactures word for it according to jet size? Cause if so thats very dumb to do. Different elevations & other factors can skew those parameters. So your still gonna have to tune it in to a certain extent.
enough said.
Everyone who reads your post is now dumber.
If you dont know what your talking about stop talking.
Clownshoes
I'm with you on this ATV. I'll stick to listening to the long time members like yourself & Robert way before listen to these other guys who have no accomplishments to their name or have yet to prove they even know WTF they are tryin to talk about.
I'm no expert but anyone who tells you that a 65n jet in a wet system is = to a 110n jet in a dry system is someone who doesnt know a thing about nitrous.
My car went 5.69 @ 123 in the 1/8th with a 24n jet in the direct port. (roughly 175 shot and easily a 8 second pass)
Now according to these jokers you need almost double the jet to make the same power with dry system. Maybe I should switch to a wet system and go 7's on the same jetting.
enough said.
also, what expensive **** are you talking about? if your refering to the interface, the price of the Dry plate kit w/ interface is almost the same as the wet plate kit. The interface also functions as a timing device, so your really saving money. Other than that a dry kit requires the same accesorries any wet kit needs to function consistently and properly.
Same goes for the interface. It does not "trick" the computer into anything. There IS additional airflow so the interface TELLS the computer to add more fuel. No different than the MAF does on an NA application.
As for the debate, there really isnt one i dont know why this question keeps coming up. Neither is safer than the other when properly setup.
I dont want you to think im jumping down your throat, i actually enjoy conversations like this, everybody learns new stuff when a lot of information gets out there.
