Nitrous problem
Old Jun 24, 2009 | 08:34 AM
craze4speed's Avatar
Default Nitrous problem
i just put a hsw plate kit on an '05 gto i also installed the hsw micro edge controller, when the nitrous is being sprayed it feels like it is surging, almost like it has a progressive on it. its like it is not spraying it steady, i have checked the grounds which are on the cylinder heads, and looked everyting over, and i dont see anything, before i go crazy i just wanted to see if anyone else has ran into this problem. and the bottle is mounted correctly so i dont that is a problem, thanks
Old Jun 24, 2009 | 08:44 AM
Bird_Of_Prey's Avatar
How's the bottle pressure? Eliminate the micro edge and see if the problem still arises.
Old Jun 24, 2009 | 08:58 AM
Nick@HSW's Avatar
Jump over and fill out a support ticket. We'll have you reset the microedge to eliminate any settings that could be causing the surging effect.
www.harrisspeedworks.com/support
Nick
Old Jun 24, 2009 | 10:05 AM
Chris@NitroDaves
Guest
Posts: n/a
You also might think about changing the grounds to a good chassis ground.
-Chris
Old Jul 16, 2009 | 08:45 PM
I did eliminate the controller and the problem is still there, and i have also changed the grounds, no difference. i have installed 10 or more nitrous kits, and have never ran into a problem like this before???
Old Sep 26, 2009 | 01:48 AM
kc533's Avatar
I have this exact same issue. Come to any conclusions yet?
Old Sep 26, 2009 | 04:46 PM
YURVIEW's Avatar
I am just subscribing.... this seems to be a more and more common compaint about the HSW microedge. was considering buying one, but think i'll wait till HSW can give an explaination....... and solution
Old Sep 27, 2009 | 03:38 PM
Nick@HSW's Avatar
Guys, check your settings. 99% of the time its because something isn't set correctly in your settings or the TPS value has changed, etc. If you have a problem try contacting us directly.
Nick
Old Sep 27, 2009 | 03:39 PM
Nick@HSW's Avatar
I think you'll find plenty of satisfied microedge users.
Nick
Old Sep 28, 2009 | 06:40 PM
kc533's Avatar
Issue resolved, mine indeed ended up being setting related
Many thanks to HSW tech support!
