what is missing from NXL kits?
Old Nov 12, 2003 | 02:47 PM
BigPlanTransAm's Avatar
Default what is missing from NXL kits?
i have the kit and can already tell that i am missing parts. instead of plowing ahead and having to part by part as i come across it as missing, does anyone have a list of what is usually missing so i can get them all in one batch and not have to find them one by one as i install it?
Old Nov 12, 2003 | 06:16 PM
Brains's Avatar
Just lay out your kit before installing to make sure its all there... You won't know what/if anything is missing from YOUR kit until you check
Old Nov 13, 2003 | 08:26 AM
93LS1RX7's Avatar
The more common stuff was:
Nitrous Y connector
2 short feed lines from the Y to the rails
#18 nitrous jets
If you dont have that stuff give your supplier a call but dont abuse it, and just call to get extra stuff or because you were to lazy to lay it out yourself and check, if you actually did get it.
Old Nov 13, 2003 | 09:10 AM
Nitro Dave's Nitrous Outlet's Avatar
I beleive the only kits that were missing parts was the first batch that we received.There were only 10 kits in that batch.So if you did not get that first batch you should be ok.
Dave
Old Nov 13, 2003 | 02:35 PM
i did get one of the very first kits and i dont have the Y connector or the lines that hook to it. i havent checked my jets yet though but theres soo many of them i didnt think any were missing.
Old Nov 13, 2003 | 03:20 PM
just checked my jets, and while none were missing, one was completely illegible. the process of elimintaion tells me thats it's a #10 jet so i asked for one of those along with the Y fitting and the small tubes that connect to the rail from there.
Old Nov 14, 2003 | 06:29 AM
93LS1RX7's Avatar
The ones from the Y to the fittings arent small. They are braided lines not those little tiny suckers.
Old Nov 14, 2003 | 02:54 PM
well i didnt get any braided lines other than the bottle feed line so i hope they knew what i was talking about and send me the right parts
