New best!
Old Nov 15, 2003 | 12:23 AM
The Guy in MY 99TA's Avatar
Default New best!
Well its not MUCH to be proud of but I ran a 11.490 @ 115.2 tonight. The weather was great! I wish I could have been on slicks with the short-belt and a little more bottle pressure(about 900 psi) ---- I was waiting on it to warm up but CERTAIN PEOPLE wouldn't leave me alone about making a nitrous pass before they left SHAWN!!!!! and I think I could have went better. I think I could have sprayed the car a little sooner off the line(sprayed about 20 feet out) but I was scared it wouldn't hook and I didn't make another pass. But over all I'm happy b/c I ran a new best on motor too... 12.46 @ 106.
I think the 30th of this month I might try to go out on slicks and skinnies with some bottle pressure and the shortbelt and shoot for some 11.30's.
Josh S.
Isn't that a bump on the nitrous list and a bump on the quickest stock internal power adder.... I might not get the quickest bolt on power adder but I will be the fastest with exhaust manifolds(atleast no1 has listed that they ran in the 10's with em and thats my goal).
Old Nov 15, 2003 | 02:49 PM
redsscamaroboy's Avatar
Nice run Josh. I ran a best of 119 mph after i added headers. I have been thinking about 3:73 gears, What rpm are you at when you cross the traps?
What was your 60 ft times?
Dave
Old Nov 16, 2003 | 02:45 PM
Ooops I need to edit the gears. That was with 3.23s I busted the 3.73s about 2 weeks ago and put my stock 3.23's in. IMO the gear change really isn't worth it. IF I were you I might go with a 3.42 but the 3.73's aren't worth it b/c they WILL break.
I cut a 1.58 on the nitrous pass and I didn't spray it till I rolled out a bit so I think I can get it down to a 1.52 or so if I spray it sooner or almost out of the whole.
If I could have made another pass I think it was gunna go faster but I didn't and probably for the best b/c I probably would have broken someting. I was going to the track today but the weather didn't hold up.
Josh S.
Old Nov 18, 2003 | 03:05 PM
Thanks for the info, good luck on your quest for 10's with manifolds.
Dave
Old Nov 18, 2003 | 04:33 PM
whiteLS1's Avatar
why dont you jet UP say 175 tuning, race gas you will be good to go and get closer to your goal.
i know a guy that has 250 shot two stage setup on his car stock bottom end.
matt
Old Nov 18, 2003 | 10:09 PM
I have tried to go with a 150 and the car doesn't seem to change it runs the same times OR a .1 slower on the 150. I think its running lean BUT the O2's seem to stay around 910 or so which is a little high but not all that bad.
I have plans on a NOS direct port with a serperate fuel system with a 175 shot. I also need a ported TB(working on that right now) a pulley, a better converter, an LS6.... or FAST intake, and a good nitrous tune( I'm gunna buy LS1 edit real soon)
I am gunna try to run on slicks Sunday so I can spray the car outa the whole.
Josh S.
