mallory 685 help
Old Jul 10, 2009 | 12:04 AM
robsquikz28's Avatar
Default mallory 685 help
I lost my notes on the wiring for this box and need help wiring....
where do the wires go for wiring in the window switch???
which wires are for the window switch??
with this window switch active will i still need a wot switch? probably due to the fact it has a window switch for arming and disarming the n20
thanks always
Old Jul 10, 2009 | 09:11 AM
Grant@NitroDaves's Avatar
LS1TECH Sponsor
page 2....look for: 685,6851 HyFire 6 Series
http://www.malloryperformance.com/In...heetsList.aspx
Old Jul 10, 2009 | 11:28 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by robsquikz28
with this window switch active will i still need a wot switch? probably not correct due to the fact it has a window switch for arming and disarming the
n2o!!!
thanks always
Yes you will still need some form of WOT detection, as you do not want to spray at part throttle.
Old Jul 10, 2009 | 12:31 PM
awesome thanks so only purple is used for the window switch thats what i thought...thanks again nitrous outlet and nitro daves
Old Jul 10, 2009 | 12:51 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
yep....and You're welcome from Nitro Dave's Nitrous Outlet
