Plug gap for a 200 shot
Old Jul 20, 2009 | 04:58 PM
jc99ls1ss's Avatar
Originally Posted by ATVracr
We run our back shocks pretty tight, try tightening yours up.
What vehicle? What type of shocks are you running? I have a 3 - 5 drop and overloads out. The back is pretty soft. You would think that would help on weight transfer but just to soft. I am thinking on putting overloads back in to stiffen it up a little. And that is on hoosier 28x10 slicks. Put br7's on order today also.
Old Jul 20, 2009 | 09:22 PM
02silverbird's Avatar
You'll get it dialed in hang in there buddy
Old Jul 21, 2009 | 07:05 AM
jc99ls1ss's Avatar
Went by Jeff's the other day. he has two spring packs he said I could get the overloads out of. Just gotta take time to go get them now. I may go SCR with ya'll this weekend and make some motor passes if I get the springs in.
Old Jul 21, 2009 | 03:11 PM
I'm not gonna be able to make it got to work and still having 2-3 shifting problems,got to pull the tranny again? Just about ready to buy a finish line and be done with it!!!
Old Jul 21, 2009 | 09:28 PM
JD Race Cars's Avatar
Hang in there buddy, you'll get it figured out! LOL Maybe it will hold up this time!
Old Jul 21, 2009 | 09:52 PM
Z-RATED94's Avatar
Since this thread has already been side tracked, what gear are you in when making a pass? If 3rd, try shifting to overdrive once the 1-2 shift has happened. That and overfill your trans by a half a quart. I'm serious and have seen it help more than once.
Old Jul 22, 2009 | 09:23 PM
We were actually doing that when the tune wasnt correct. The tune has been corrected but the damage is already done to the clutches. Gotta pull it and put new 3-4 clutches. The overdrive trick did work though! Spot on!
