HSW Warranty
Old Jul 25, 2009 | 12:52 PM
ls1redline's Avatar
Default HSW Warranty
Just trouble shooting why my nitrous wasnt engagind and traced it down to a faulty solenoid. It works fine without and pressure but as soon as I open bottle and apply nitrous pressure the noid wont click. HSW isnt open today so im just trying to figure out if they offer a warranty. Ive had the system for a little over 10 months and used it maybe a dozen times. Thanks for any help!
Old Jul 25, 2009 | 01:13 PM
SkullV's Avatar
What is your bottle pressure at? Get it at 950psi and see if it works then. There were a couple guys with 1300+psi who had problems with the solenoids opening and when they set it at 950psi everything worked fine. The HSW kit is rated at 950psi.
Old Jul 25, 2009 | 01:51 PM
Mike@HSW's Avatar
1 year warranty on solenoids. Also curious what pressure you were running at. Either way you'll be covered, just make sure you send it in before the year mark.
Old Jul 26, 2009 | 10:30 AM
ls1redline's Avatar
No it was a little under 900 when I tested. At track when i had issues it was upward of about 950-1000. Purge solenoid is functioning propery and it is smaller in size! Thank for your help HSW. I think my year mark is late August so Ill ship it off Monday. Any specifics I should include?? i believe I have my original receipt.
