nos controller for m6?
Old Aug 2, 2009 | 10:39 PM
stock01ws6's Avatar
Default nos controller for m6?
I have a t/a with a m6 and am looking for a nos controller. Looking for ideas on which ons to look at. Looking for something that is progessive and I can have come on in second gear.
Old Aug 4, 2009 | 03:58 PM
Brian Coles's Avatar
Search Harris Speed Works
Old Aug 4, 2009 | 04:01 PM
streetassasin's Avatar
fjo controller is probably what your lookin for
http://nitrousoutlet.com/catalog/pro...product_id=952
Old Aug 4, 2009 | 04:56 PM
stock01ws6's Avatar
How do they work with the shifting. I am looking for something that will hit in first and slowly ramp it in and by second have it fully engauged. The thing is are they spraying during the shift?
Old Aug 4, 2009 | 05:04 PM
Mike@HSW's Avatar
how big of a shot are you spraying?
Old Aug 5, 2009 | 01:42 PM
stock01ws6's Avatar
Its a 61 n2o jet with a 31 fuel at 11.5 air fuel.
Old Aug 7, 2009 | 01:36 AM
stock01ws6's Avatar
I think if I can get the 60's down I will step up to a 200. Right now it has a 150 n2o jet with a 100 fuel jet and picked up 125 rwhp. I still need to put a racetronics intake in.
Old Aug 7, 2009 | 11:29 AM
Chris@NitroDaves
Guest
Posts: n/a
If you are going to have a laptop with you everywhere the car is going to be then i'd go with the FJO unit http://www.nitrousoutlet.com/catalog...product_id=952
If you aren't going to be carring a laptop then i'd suggest the NOS mini Contorller http://www.nitrousoutlet.com/catalog...roduct_id=1539
-Chris
 Michael S. Palmer
Old Aug 7, 2009 | 11:53 AM
Mike@HSW's Avatar
you mean racetronix pump? first things first, figure out what issues you are currently having and correct them. No sense in adding a controller into the equation which could further complicate things. What kit is this on? if you are jetted for a 150 shot and your running a 100 fuel, you have a problem. please give us as much detail about the car as you can.
There is no reason you would have to progress a shot of that size. I would spend the money working on your suspension rather than trying to progress and lock out gears. A majority of your ET is in the 60'. If you have a kit, you want to utilize it to bring that 60 down.
Old Aug 9, 2009 | 08:02 PM
stock01ws6's Avatar
The suspenion setup is perty much done. If I put the slicks back on I can pull atleast a 1.7xx on motor and sill bog. I could spary out of the hole with a controller on it and have it progess in to help bring it down on the slicks. I just started playing with dr's. It is just seat time getting use to the car.
The car has a NOS plate with pro shot n2o and cheater fuel noids and a -6 feed line (nos plate kit). The fuel pump is a stock pump with a hot wire kit and a 255 inline. The engine is a iron block lq4, 241 heads that have been ported with 2.02\ 1.60 valves and a ls6 intake manifold. The cam is a LG g5x3 cam(234/242 615/605 114 these are what people are saying the specs are) longtubes no cats and 3.90 gears.
Right now I know to change to ngk tr7 plugs and read the plug for the tune. It has tr6's in it that have a .35 gap. On the dyno doing a 4th gear pull it isn't seeing any dention. So besides reading the plugs what else can I like at? And I will be putting a racetronics intank fuel pump in it soon to make sure I have the need fuel.
