Why is rich so dangerous?
Old Aug 7, 2009 | 06:49 PM
TS6's Avatar
TS6
Default Why is rich so dangerous?
In doing as much reading as I can, I keep seeing how running rich is so much worse than going lean, that running a little fat can lift ring lands. I've been running FI for years, we've never hurt a motor making a pass or two with a fat A/F. Granted, they slow down, but a 10.0:1 pass on a blower car isn't gonna blow **** up. Why is it different on N2O?
Just trying to understand.
Old Aug 7, 2009 | 06:53 PM
jmill96Z's Avatar
My understanding is that the mixture will creep under the ring land and ignite. Something's gotta give.
Old Aug 7, 2009 | 07:20 PM
TS6's Avatar
TS6
Why more so on spray than any other type of setup? Air/fuel is air/fuel, doesn't matter how you administer it. I have always understood that excessively rich tunes will wash the rings out over time, but from what I'm reading here it sounds like 1 pass below 11:1 is like sudden death.
Old Aug 7, 2009 | 07:22 PM
Robert56's Avatar
I gree and once the ring lang goes it often turns into a blow torch effect area, then the cylinder walls need attention and so on...
Robert
