Standalone pressure?
Old Aug 10, 2009 | 11:33 AM
BigDB's Avatar
Default Standalone pressure?
What are most running their standalone fuel pressure at, I know I need to set the pressure flowing not deadheaded to the noids. I need to order a gauge and im thinking im gonna need a 0-100psi gauge.
Old Aug 10, 2009 | 11:55 AM
JAX04's Avatar
good question, im interested as well. are you going to run high pressure or low pressure?
Old Aug 10, 2009 | 01:20 PM
BigDB's Avatar
Im thinking high pressure, shot is 300 100 on 1st stage and 200 on second. When pulling from the rail it high pressure so I dont see why this would be different
Old Aug 10, 2009 | 01:29 PM
blown69ls1's Avatar
Call Creig at Nitrous Express. He has a very nice gauge. And it is A++++++++ customer service. I have a fogger with a low pressure stand alone. I run my around 5.5-6.125 pending on tune. EVERY car is different tho! Just call Creig at NX.
Old Aug 10, 2009 | 01:32 PM
Mike@HSW's Avatar
is this on a direct port system? without a doubt, low pressure. It's much easier to tune a system on low pressure. there really is no performance gain from running high over low unless you are running a nozzle or plate spefically made for high pressure.
Old Aug 10, 2009 | 02:45 PM
BigDB's Avatar
Its a Nitrous Outlet plate dual stage
Old Aug 11, 2009 | 01:26 PM
BigDB's Avatar
Finally got an answer, the Nitrous Outlet plates are jetted for 58psi so Ill be running high pressure. I was advised that If it was a direct port that low pressure would be used due to the 8 fuel jets and each cylinder distribution for fuel atomization.
