lightweight nitrous piston for Lt1
Old Aug 10, 2009 | 02:56 PM
SPRAYED Z's Avatar
Default lightweight nitrous piston for Lt1
what is the best and lightest nitrous piston to use on a .030" bore, he would be using the stock rods,crank but just piston slapping it together. What would be the best piston for that and hitting it with over a 200 shot. Also what would be better domed or flat?
thanks, TOM
Old Aug 13, 2009 | 02:26 AM
robsquikz28's Avatar
im sure if you do a search you might find something!
Old Aug 13, 2009 | 08:54 PM
SPRAYED Z's Avatar
Anyone I have not found anything on this!!!
Old Aug 14, 2009 | 09:17 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Call the major piston manufacturers, JE, Wiseco, Ross, etc and get their suggestions.
Old Aug 14, 2009 | 09:21 AM
z28rob18's Avatar
idk about other pistons but the diamond ones i just put in my block were very light.
Old Aug 17, 2009 | 05:56 AM
skinnies's Avatar
If he is using the stock rods, no reason to spend a lot on a piston.
