nitrous nozzel question
Old Aug 13, 2009 | 01:35 AM
stangtrader's Avatar
Default nitrous nozzel question
i have a mostly complete kit im borrowing from a friend minus jets and a fogger nozzel.it is a wet kit and i plan on only running up to a 150hp shot.
what do you guys think of this nozzle?also is it semi safe to do a 150 shot on a stock tune with minor bolt ons or is a 100 shot the most i wanna go for now.i like this nozzle it would work better as far as hook up but im not familar
with dynotune nitrous.
http://cgi.ebay.com/ebaymotors/Nitro...Q5fAccessories
Old Aug 13, 2009 | 01:54 AM
WYATT318MOPAR's Avatar
Don't think I would be spraying that much on a stock tune, assuming it doesn't have a good fuel pump or correct set of plugs to back up the shot. This is a good nozzle though instead of the ebay one.
http://www.summitracing.com/parts/NOS-13700NOS/
Old Aug 13, 2009 | 01:56 AM
SexyTransAm's Avatar
stock tune will be fine just run some tr6 plugs at .035. and make sure the pump is good and not goin out! if it is weak at all get a 255
Old Aug 13, 2009 | 02:15 AM
was deffinatly gonna do plugs,was looking at that nozzle and im thinkig of
it the main thing i like is putting less tension on the lines.one thing i noticed
is different manufacters list different size jets for the same size shot.thinking on the fuel side going with the largest size recomened size to be safe unless any one has a better suggestion.the kit is a cold fusion 5.0/ls1 kit but my friend cant find the jets and nozzle so im trying to figure this mis matched crap out.would just spend$600 and get the hsw kit but trying to save for a house.
thanks joe
Old Aug 13, 2009 | 10:48 AM
Chris@NitroDaves
Guest
Posts: n/a
That nozzle should be fine for what you are wanting to do.
