microedge lean cut off.
Old Aug 13, 2009 | 11:10 PM
johnLs1camaro's Avatar
Default microedge lean cut off.
From what I thought the microedge has the lean cut off. I wired my wideband to it, and picked the aem wideband selection on my microedge controller, and I couldnt figure out how to set my lean and rich settings for it to shut down the nitrous.
Old Aug 14, 2009 | 08:38 AM
Grifter's Avatar
There is an option in the Triggers Menu that has MIN AFR and MAX AFR. Just set those to what you want and you should be good to go.
