timing tuner issues
Old Aug 23, 2009 | 05:13 PM
rpmauto's Avatar
Default timing tuner issues
I decided today to do some checking over of the n20 system as i have never had a good nitrous pass on the 402 yet. I unhooked the fuel supply and took the nitrous feed off the plate, open bottle arm system activate wot switch and it sprays for like a second then both solenoids deactivate. Of course i thought it must be the min rpm i have set on the timing tuner. So i set that to zero with no delay and same thing. If i let off the microswitch and press it again it will spary for another sec then nothing. Is this the proper way to test this??? I cant think of any other way.
I put the timing tuner in when i put the 402 in, just to retard the timing. Before that i had a msd window switch. I have sprayed it a few times and it has never felt like it did with the stock motor. Most times i will only pick up like 4 tenths on a 150 hit. Basically it is spraying for only a second everytime i shift.
Old Aug 23, 2009 | 10:04 PM
rpmauto's Avatar
i will call n2o outlet tommorw but i think i am going to ditch the timing tuner and go back to a msd window switch. With efil live i can have a tune set up just for spray. I only spray at the track once in a while anyway.
Old Aug 24, 2009 | 10:02 AM
Nick@HSW's Avatar
What are your settings?
Nick
Old Aug 24, 2009 | 10:08 AM
rpmauto's Avatar
i set the delay to 0 and the min rpm to zero to test it.
Old Aug 24, 2009 | 11:12 AM
Nick@HSW's Avatar
what about the dip switches?
Old Aug 24, 2009 | 12:29 PM
rpmauto's Avatar
all dip switches set to zero, (no delay) it had # one dip switch on before, ie .2sec delay. # 4 switch is for max rpm limit on or off.
