Fuel Pump
Old Sep 2, 2009 | 03:15 PM
Weist's Avatar
Default 78mm Wet Plate Kit
Looking to run a HSW Sudden Impact 78mm Wet Plate Nitrous Kit and just wondering if I should upgrade my fuel pump? (Any suggestions on a new pump) Looking to run between a 125 to 150 Shot
Should I run a window swith?
Mods:
Stock LS1
Stock Heads
K&N Air Filter
SLP Air Lid
MAC Long Tube Headers with catted y-pipe
SLP Loudmouth 1
Fuddle 3600 stall converter (4L60E)
B&M 24k Trans Cooler
TSP Cam 233/239 .595 .603 112LSA
TSP Pushrods
PRC Dual Spring kit with titanium retainers
Crane Lifters
LS6 Oil Pump
Rollmaster Timing Gear Set and Chain
Old Sep 3, 2009 | 11:17 AM
Weist's Avatar
Bump...Anyone
Old Sep 3, 2009 | 11:47 AM
Grant@NitroDaves's Avatar
LS1TECH Sponsor
People have gotten away with using their stock pump for 100, maybe even 150hp Nitrous. The Walbro 255lph is good to about 550hp alone and with a Hot-wire Harness 630-650hp.
Its always a good idea to have a Window Switch. Ours have a Digital TPS Function and Multi-gear Lockout as well as the Window feature.
Old Sep 3, 2009 | 12:02 PM
jmill96Z's Avatar
I am still running on a 255 without a hotwire kit. I would look at getting the HSW Micro Edge Controller with your setup. It is the most complete controller out there, and is crazy cheap. Basically it is a Window Switch, 2 stage controller, lean shutoff, pedal feature, delay timer, gear lockouts, TPS switch.....the list goes on.
