alternate WOT switch mounting points
-on the TB
-under the pedal
You could alternately arm the N2O system with a master switch, and have a button either on your shifter, or on a cord, and only hold the button down after 1st gear. Keep this button in line with all other safety considerations.
Alternatively, you could do as I am doing, and use the HSW MicroEdge to lock out 1st gear.
A lot of guys mount on the shifter so they can spray in 2nd gear.
The problem is I've only seen it on race shifters where they just drilled into the housing.
Be careful trying to squeeze it on a stock unit. It would suck to come on unexpectedly or short something out??
