Automatic Timing Retarding
Old Sep 24, 2009 | 06:31 PM
WS.666's Avatar
Default Automatic Timing Retarding
I'm trying to put together an "occasional use" Nitrous System for use on my currently N/A H/C/I swapped LS1. I want to run at peak performance 99% of the time, but when I need it, I want to spray and have the timing retarded on the fly and run at peak performance under spray. Is there a cheaper alternative to the MSD Digital 6 (~$320) or Mallory HyFire VI Digital Ignition (~$260)?
Does the Harris Speed Works Micro Edge do this?
Old Sep 24, 2009 | 08:21 PM
jman54002's Avatar
the best luck I found was a timing tuner...quick plug and play. I have seen them for sale in the sale section. but they are around 260.00
Old Sep 24, 2009 | 08:48 PM
slammin86's Avatar
Iat tricker. Dirt cheap to make. Have your tuner adjust your iat timing pull tables as needed.
Old Sep 25, 2009 | 05:14 PM
Chris@NitroDaves
Guest
Posts: n/a
We have used all the timing units on the market for the LS1 except the hsw unit. We have had the best results with the Lingenfelter unit.
http://www.nitrousoutlet.com/catalog...roduct_id=3467
