Getting 4* of KR with 7* already pulled...
Old Sep 27, 2009 | 11:37 AM
273sunsetZ's Avatar
Default Getting 4* of KR with 7* already pulled...
Put the 150 tune back in the car last night which uses the resistor mod and went to test it out. With 7* pulled out it went to 4* kr @ WOT and started to slowly work its way down to 1* kr before i let off.
Last year at this time when i first sprayed it with this tune and the same type plug (TR6) it had 0 knock, but i had 9* pulled out then and not 7*. Where should i go from here?
TR7 plugs, if so what gap and how much timing should i pull?
Keep the TR6's and go back to 9*?
Old Sep 27, 2009 | 12:35 PM
slammin86's Avatar
You tell us how much timing you are pulling, we also need to know what your peak timing is on the bottle.
Old Sep 27, 2009 | 12:48 PM
273sunsetZ's Avatar
Peak timing is 21.5
I've got the data log of the pull if anyone would like to take a gander. Let me know if you would like to know anything else.
Old Sep 27, 2009 | 12:49 PM
273sunsetZ's Avatar
N/A, its 28* total, for reference
Old Sep 27, 2009 | 01:42 PM
nikon1999's Avatar
i would try a tr7 plug for a 150 shot.
Old Sep 27, 2009 | 04:37 PM
ShiznityZ28's Avatar
Knock sensros are just aboput useless. what do the plugs look like.
Old Sep 27, 2009 | 06:26 PM
273sunsetZ's Avatar
I'll have to make a pull this wk, pull over right after and check the plug. I'll let you know what the a/f is also once we get it done.
