Advanced MicroEDGE + features!!
Not only does it display bottle contents and progress the solenoids, but there is also a more advanced feature set for those that want hands on control!
Inside the menu you can alter the shape of the progressive curve. That means instead of a straight linear curve you can shape the curve to either have a fast build that tapers off or a exponential growth that compounds as time or rpm increases, etc. This feature is great for dialing in traction! Or slowly building progression to bring the activation RPM slightly down.
Always taking things one step further, you can also implement different curves for all gears! Need to slowly bring progression in on 1st gear but 2nd gear can handle a quicker progression? Not a problem with the MicroEDGE! Each and every gear can have its own progressive curve that you program! This is also accessed directly from the microEDGE menu system.
For those looking for more information, here is a link to the microEDGE + and the + upgrade. If you have any questions concerning it please do not hesitate to ask!
Nick
