another stockish ls1 nitrous question.
As for wet or dry everyone has there own opinion but mine is this. Using the factory LS1 pcm you can not beat a properly designed and tuned wet system.
Let me know if I can answer any questions for you.
Dave
Wet or dry doesn't really matter. If you have stock injectors and dont want to upgrade you might want to stick with wet. If you have larger injectors, dry works just as well on any setup regardless of the computer being stock, especially running our interface controller. Changing switches is easier than changing jets. You also gain the ability to pull timing with it. Nothing else on the market compares to our wet plate kit and our dry kit works just as well.
All depends on what else you have going on in your setup. Give us some more detail.
thanks
