LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Nitrous Oxide (https://ls1tech.com/forums/nitrous-oxide-10/)
-   -   Microedge won't activate noids????? (https://ls1tech.com/forums/nitrous-oxide/1189245-microedge-wont-activate-noids.html)
YURVIEW Oct 8, 2009 07:37 PM
Why would it not be activating the solenoids?? I tried the test..... Set RPM to 0 and even set TPS to 0. Turn on kit, open throttle and nothing happens.......... I really haven't had a chnce to trouble shoot it as I ran out of daylight. But I need this operational by tomorrow. Please help TIA
Sofls1 Oct 8, 2009 07:45 PM
Check all your connections- both to the microedge and the kit. Ensure all your grounds are good. Also check the relay and make sure its good.
If that all checks out, do you have the leanout feature on without a w/b or n/b O2 hooked up? That is a possibility.
Could you have possibly toggled to a different file?
Good Luck!
YURVIEW Oct 8, 2009 08:00 PM
relay is good, as kit was working before Microedge. using same ground i had for the ralay, since Microedge calls for the relay ground to connect to it. Any other ideas????
Caribe Oct 9, 2009 02:27 AM
I had one of the original versions of the Microedge. The only way it would test was with the car running. Disconnect nitrous lines. Lower rpm range(1300 or so), turn tps off, or lower trigger value, leanout delay off. Have the lines in a bottle, arm system and rev car to rpm value, it should fire. Hope that helps.
Grifter Oct 9, 2009 07:45 AM
These threads have some common MicroEdge set-up problems.
https://ls1tech.com/forums/nitrous-o...ease-read.html
https://ls1tech.com/forums/nitrous-o...setup-hsw.html
Nick@HSW Oct 9, 2009 10:17 AM
Yup, exactly like described above. Take a few minutes to familiarize yourself with the controller first. Don't worry about changing things because you can simply reset it to factory settings. If you still aren't sure about anything feel free to give us a call or shoot me a PM.
Nick
YURVIEW Oct 9, 2009 10:33 AM
Yea I'm an Idiot!! after goin over it all this morning, i realized i had set my 1st Gear to lock-out, so of course it wouldn't spray during the test. Changed it, and it's working Fine!!! Thanks for the all help guys. Sorry for wastin a thread!
Nick@HSW Oct 9, 2009 11:33 AM
No, hey thanks for coming back and answering what the issue was. Now someone can hopefully use this to help them one late night to test it. :chug:
Nick
Sofls1 Oct 9, 2009 12:00 PM
I kinda figured it was something like that. The microedge is really easy to use, but if your in a hurry it can sometimes get confusing. (especially if your new to it) Glad to hear you got it going!
© 2026 MH Sub I, LLC dba Internet Brands
