Used nitrous kit?
Old Oct 21, 2009 | 02:12 PM
2002t/a06's Avatar
Originally Posted by 90TSiAWD
I heard you couldnt becuz the type of rubber isnt thick enough but I def will I bought a fernco to mount it in but it dosent fit.
I had mine mounted in my stock bellow a long time ago, seemed like it worked fine to me. Now i have it mounted in my slp bellow that i had bought a while ago.
Old Oct 21, 2009 | 02:34 PM
JL ws-6's Avatar
Race your car!
If you buy a used kit, jsut be sure to clean the lines all out, clean the nozzle really good, and just rebuild the solenoids right away so you know they are o.k... this can be done yourself, or send them to one of the vendor's on here and they can do it quick/cheap enough.
Obviously look @ the bottle, brackets, lines, make sure they are all in good working order.
As long as they are, you should be good to go.
Old Oct 21, 2009 | 04:54 PM
tiresmokinV8's Avatar
I bought a used kit this past summer for my truck. I wired everything up and tested the noids without the lines hooked up so i could here all the noids click. I then hooked the lines up and ran it without the lines hooked to the nozzle to purge the lines and system and check for leaks before finalizing. everything has checked out so far and my kits older as I had to get the bottle recertified before summit racing would fill it. How hard is it to rebuild the noids? can I do it myself and whats the parts replaced?
Old Nov 1, 2009 | 05:21 PM
90TSiAWD's Avatar
Got everything hooked up and sprayed a 75 shot last sunday, it was wow!
What should my 1/4 mile time be? Full exhuast, Lid and 75 and 100 shot. 2.73 gears.
Old Nov 1, 2009 | 06:03 PM
custm2500's Avatar
Ph.D. in HUBRIS
Glad to hear it all worked out!
Old Nov 3, 2009 | 12:08 PM
90TSiAWD's Avatar
Any idea on what I should run?
Old Nov 8, 2009 | 09:49 PM
90TSiAWD's Avatar
I ran a 12.89 @ 111.
I dont think it was working correctly though because my bottle isnt mounted right because im not getting liquid, I have it sideways in the bottom where the T-Tops go with the outlet pointing down, is that ok? Where do most people and how do they mount there bottle?
Old Nov 8, 2009 | 10:16 PM
2002t/a06's Avatar
I think the bottle is supposed to be around a 15 degree angle? people mount their bottle's all over the place. spare tire well, trunk, trans tunnel, and many other places
Old Nov 8, 2009 | 10:19 PM
90TSiAWD's Avatar
I just read up on it a little bit, I have to move the bottle so the outlet is pointing towards the rear of the car so the siphon tube will be oriented right.
Old Nov 9, 2009 | 05:48 AM
custm2500's Avatar
Ph.D. in HUBRIS
Unless someone has taken the siphon tube out this is not correct. Valve always points to the front of the car. Again if someone has move or alerted the siphon tube for there application then you either have to mount it similarly to how they did or you can change the siphon tube back to original orientation.
Old Nov 9, 2009 | 10:01 AM
Nick@HSW's Avatar
How is the bottle mounted in the car? Mounting depends on mfg. but most of them are universal. For example with ours if its mounted side to side the outlet will need to be pointed at a slight angle down and to the rear of the vehicle.
Nick
Old Nov 10, 2009 | 08:48 PM
  #32
90TSiAWD's Avatar
Its mounted sideways in the trunk where the t-tops usually go, with the opening valve toward the spare tire.
