tuning for nitrous
Old Oct 14, 2009 | 01:01 PM
02b4ccamaro's Avatar
Default tuning for nitrous
i have a cam only car and i wanted to put a 125shot on it, wanted to know what most people are doing as far as the tune? do you let the car make all the timing corrections? or is it better to have a nitrous tune?
Old Oct 14, 2009 | 01:21 PM
ShiznityZ28's Avatar
you should always have the car tuned. Did you have it tunned for the cam?
Old Oct 14, 2009 | 02:33 PM
No i was wanting until i got the nitrous installed, so i could do a motor and a nitrous pull.
Old Oct 14, 2009 | 03:25 PM
Than i would get the motor tune done on the dyno. then take it ot the track to clean it up. After the motor tune is good than you can get the nitrous tune from there. IF you want to be able to adjust it id put something liek the lingenfelter timming tunner on it.
Old Oct 14, 2009 | 03:31 PM
well i have hp tune, so i can take timing out at the track. isent rule of thumb 1/2 a degree for ever 100hp
Old Oct 14, 2009 | 04:32 PM
david vericker's Avatar
Rule of thumb is more like pull 2 degrees for every additional 50hp shot.
