Dyno results 100 shot with graph
Old Oct 23, 2009 | 04:37 PM
Chris@NitroDaves
Guest
Posts: n/a
Originally Posted by TA1364
So pull 6 degree total?
After looking at the graph I might be able to go to the 100F. I'll get the graph up on here a little bit and see what you think.
Correct you will be pulling 6* of timing. Also one way to help do away with the lean spike would be to shorten the fuel hose up at least 4-6in. Also we like to see the AFR around 11.8
Old Oct 23, 2009 | 05:21 PM
squale iii's Avatar
Originally Posted by john563
the heads aren't the greatest,but it does have a few pluses on its side..
Please explain.
Old Oct 23, 2009 | 05:22 PM
squale iii's Avatar
I don't know **** about nitrous and timing...but 6 degrees seems like alot for only a 100 shot doesn't it? I had a 150 shot wet kit and I'm pretty sure we only had 2 degress pulled for mine and had no issues with detonation. I could be wrong tho lol
Old Oct 23, 2009 | 06:16 PM
john563's Avatar
I was thinking the same thing..I thought rule of thumb was 2 deg for every 50rwhp,so wouldn't 4 deg be enough.. I'm thinking of adding a 100 shot and thought 4deg would be enough,but I guess not..
Old Oct 23, 2009 | 06:59 PM
IWGF's Avatar
You're better off pulling more timing to be safe. That's common sense. You guys are gonna blow your **** up.
Old Oct 23, 2009 | 09:42 PM
TA1364's Avatar
I really dont think the knock sensors were reading real knock. They do this off the bottle and on my old car too which was n/a. I think its just a 98 problem.
Old Oct 24, 2009 | 12:00 PM
TA1364's Avatar
Added graph on first post
Old Oct 24, 2009 | 01:11 PM
john563's Avatar
I had some knock on mine..Replaced the knock sensors and all was good
Old Oct 24, 2009 | 06:19 PM
firefighter813x's Avatar
I replaced the knock sensors from a different year and sealed them well too. FYI I sprayed my car with a 150 hit today twice and it was sick. Autolite 103's and a lot of timing taken out.
Honestly, I haven't heard one benefit of having a '98 LS1. Apparently the heads aren't as good (who cares) the rod bolts are weak, the PCM isn't as user friendly for tuning, and the oil passages on the '97-98 blocks aren't as efficient as later years. Plus it obviously doesn't come with a LS6 from the factory.
Old Oct 26, 2009 | 10:24 AM
TA1364's Avatar
So....should I put the 100f in or leave it alone?
Old Oct 26, 2009 | 02:57 PM
LT1 Trash's Avatar
yes, mid-high 11's afr is ideal. if your a little rich then go ahead and run the slightly smaller fuel jet. you could just put the 125N jet in
Old Oct 26, 2009 | 03:09 PM
  #32
ATVracr's Avatar
I disagree but maybe thats why my **** is so slow.
We run it around 13:0 A/F
But we check every plug every pass and have different jets in most holes, different timing in most holes and different fueling in most holes. Hell I dont think we have 2 Cyl.'s that are the same.
Old Oct 26, 2009 | 04:13 PM
  #33
TA1364's Avatar
My car is way slower than yours and a much different setup.
Old Oct 26, 2009 | 04:37 PM
  #34
ATVracr's Avatar
I agree and was just disagreeing with your "Ideal" A/F ratio.
Old Oct 26, 2009 | 07:34 PM
  #35
TA1364's Avatar
So how much is being left on the table with the 125f jet in?
Old Oct 26, 2009 | 07:53 PM
  #36
camscam02's Avatar
hahahaha. gotta love this forum. Suprised more **** doesnt get blown up.
Old Oct 27, 2009 | 10:15 PM
  #37
BSmiff's Avatar
I would say a good 10-15 hp. Youre fattening it up top. You want it to be clean and clear but not on the ragged edge. Put the 100f pill in and take 2* out. Youll be golden boss. We were jacking around with the pills in my dads car and ended up going too fat. You guys all know what happens next
Old Oct 28, 2009 | 11:47 AM
  #38
JDMC5's Avatar
just clean up the KR issue and pop in that 100 Fuel jet or quit dicking around and give your car the 150 jets it deserves. I use to spray my vette in first gear and usually could get traction.
Old Oct 28, 2009 | 03:25 PM
  #39
Chris@NitroDaves
Guest
Posts: n/a
You are correct 6* is a little much to be pulling for timing on most vehicles for a 100hp shot. In this case with the KR doing what it was it would have been benificial for this individual to pull 6* of timing to help get rid of the KR.
If the car has stock timing on most applications for a 100hp shot you might not have to pull any timing but on the other hand some cars you might have to pull up to 4*. It differs from vehicle to vehicle.
Old Oct 29, 2009 | 10:59 PM
  #40
TA1364's Avatar
How about 4 degrees pulled on a 125 shot? Im thinking about either going to 125 nitrous jet or 100 fuel jet. Maybe get a few more mph.
