427 ls block n20 combo?
Old Nov 6, 2009 | 05:30 PM
cryer's Avatar
Default 427 ls block n20 combo?
I have a 427 ls block what crank length and rod length should I build for a good n20 combo? 250 shot one stage
Old Nov 7, 2009 | 06:58 PM
cryer's Avatar
nobody?
Old Nov 8, 2009 | 11:25 PM
blu byu EH's Avatar
What size is the bore? If its a 4.125 bore then all you need is 4" crank w/6.125 rods.
Old Nov 9, 2009 | 10:21 AM
JL ws-6's Avatar
Race your car!
What bore are you going with? Honestly I'd put a 6.1 rod in the car and give yourself some more room (if this is a 4.125 bore/4 inch stroke) for the ring pack above the wrist pin.
Old Nov 9, 2009 | 05:34 PM
Firehawk441's Avatar
4.130 bore and 4" stroke with a 6.125 rod.
Old Nov 10, 2009 | 12:45 AM
cryer's Avatar
block is stock bore now ,and perfect
I just dont want to send up with the ring to high.
thanks for the help
Old Nov 10, 2009 | 08:16 AM
ShiznityZ28's Avatar
3.9 crank and a gorilla piston.... Id take a 402 with a sick nitrous piston over a 427 with a "good" nitorus piston every day...
