LS2 GTO 125shot Timing?
False KR i would think is going to be between 4800-5200rpm.
The best way for you to tell if its false is to take 5* addl timing out in the cells you are seeing knock and see if its still there. If yes then its false if its gone than its probably real.
Make a few hits to make sure its consistant
the only way you are gonna see results is at the track. so get the n/a dialed in first, then do not deviate from the rule of thumb.... " 2deg retard for every 50hp shot added".
if you do not have any resources to dial in the tune, i would recomend to take 3 out of the stock values. above all, like slowgoat said, get the afr ckd.
i bet your ride will run better with 20* and 12.2afr on the 125 if the flow is optimal!!!
if you do not trust the high tech audio device and ignore it, your gonna hurt the motor.
once you reach and you consistently pull those values, then you can put a new set of plugs in at the track and pull them right after the run.
you should clearly see the timing mark on a new plug. then you'll know if you need to go to 20*, and who knows the afr might just inch up to 12.2 with just the timing adjustment. good luck!
