Still having nitrous problems!!! HELP
Old Nov 10, 2009 | 03:21 PM
01SOMZ28's Avatar
Default Still having nitrous problems!!! HELP
My nitrous has been acting up and i can't figure out what the deal is. I just got the bottle filled the other day so i could go spray it and see if it was still being weird....and it is....It cuts in and out when i spray it. I'll spray it and it will kick in for a couple seconds and then stop and then kick back in. And once in a great while it will spray the entire time. I was thinking it might have something to do with a solenoid? A friend told me it could possibly be my micro switch?
Any thoughts?
Old Nov 10, 2009 | 03:34 PM
krazy4's Avatar
Check electrical connections. If those are good, it could be the solenoid.
Old Nov 10, 2009 | 03:39 PM
Nick@HSW's Avatar
Do you know for sure if the solenoids are clicking off and on? I would lean towards an electrical issue if things are opening. If it feels like a surging I would look into bottle position or fill.
Old Nov 10, 2009 | 03:47 PM
01SOMZ28's Avatar
I don't know for sure if the solenoids are clicking on and off. It just started doing this a couple months ago and it worked perfect before. I've had this setup on my car for almost 2yrs and i've changed nothing and everything appears to be hooked up and fine.
Old Nov 10, 2009 | 04:47 PM
jetblast's Avatar
you can ck. for f noid opening by watching the afr drop when you activate the sys., just make sure the bottle is closed and use the smallest fuel jet. sounds like you are not sending enough current to the fn.
the n20 noid draws a lot of current and shares the circuit with the f noid, the condition is smilar to starving the f noid of current. since you state the sys. activated normally previously, then a your splices/crimps/grounds/relay would be my first choice to ck.
Old Nov 10, 2009 | 07:24 PM
=ZoomZ='s Avatar
Low battery or corosion in the connections
Old Nov 10, 2009 | 07:36 PM
01SOMZ28's Avatar
I just took a quick glance over my connections and made sure everything was tight. When i got to the micro switch one of the wires doesn't fit very snug. I snugged it up a little bit and took it back out and sprayed it. It didn't cutout at all (that time) i only sprayed it for about 5 seconds though. I need to get a new connector for the wires on the micro switch since that one isn't very snug. Maybe thats was the problem?
Old Nov 10, 2009 | 08:13 PM
jetblast's Avatar
i soldered every/anything that was crimped. sounds like you found the problem though.
Old Nov 10, 2009 | 08:37 PM
TA1364's Avatar
What kind of window switch are u running? I had issues with mine being set to low and it would turn on and off.
Old Nov 10, 2009 | 08:39 PM
Wildside's Avatar
i thought i would add a story we but a used all most like new tnt kit on and it work fine a few weeks went buy and added a bottle heater on it so we turne it on to get the bottle per up it was on about 875 with a full bottle so i wanted to get it up there around aleast 1000. well we forgot it was on and the per was 1200 r bad so we cool it off a little and tryed it the nit noid would not open so i took the noid a part and the noid was bad i took parts out off a another noid and fix it i guess we but to much pre on it but the first thing i would do is make sure the noid is working
Old Nov 10, 2009 | 08:49 PM
01SOMZ28's Avatar
Sorry man but your english is terrible...
Old Nov 10, 2009 | 08:51 PM
01SOMZ28's Avatar
i'm running the digital msd window switch
Old Nov 10, 2009 | 09:10 PM
TA1364's Avatar
Whats it set to shift at? Whats the window switch set to turn off? I shift at 5700 and even with the 5900 pill in the msd it still wouldnt work. I put a 6400 in the msd and it works perfect.
Old Nov 10, 2009 | 09:20 PM
01SOMZ28's Avatar
its set to spray at 3200 and off at 6100
