nx maf kit
The NX MAF kit is designed to sandwich the stock MAF electronics, you disassemble your MAF and bolt on their two ends (and plumb nitrous/fuel accordingly).
I don't think it will work with anything other than stock MAF electronics.
Rob (Bad30th)
As for fitting an 85 mm MAF, I'm not sure that will work. As Rob mentioned above, the kit is two separate plates that mate up to the center portion of the stock MAF sensor.
The kit he is inquiring about is the "GM ONE PIECE MAF SYSTEM (CORVETTES, TRUCKS, ANY GM ONE PIECE MAF) 10LB BOTTLE". It fits all GM one piece MAF applications. 35-200 Wheel Horsepower.
GM HighTech installed one in a goat here: http://www.gmhightechperformance.com...kit/index.html
Here is the kit: http://www.nitrousexpress.com/produc...ils.php?id=763
