big nitrous tuneups/how to dial in
I ran the numbers for a .031 jet at 900psi and came up with 932.5 lbs/hr. 6.79n/f ratio
.O31 at 1000. 982.9 lbs/hr. 7.15n/f
.026 at 900 659.4 lbs/hr. 6.6sn/f
.026 at 1000 695 lb/hr. 7.00n/f
These are possible values but could differ by line size and restrictions based on the jet and fuel pressure you listed.
Can somebody post up some pics of a plug after a good nitrous pass?
Can you also point out some of the details on the plug to show what it is I am looking for such as the timing mark, fuel mark and so on?
Here's a good detailed set of pictures of spark plugs. Lots of information here on it too.
Here are 2 pics from last year (2008) this was Q16 and 350 shot ...
See 1st pic the timing mark on the end of the strap and a light gray fuel ring at the bottom of the porcelin.
