What plugs to use for nitrous?
Old Dec 20, 2009 | 06:55 PM
1BADBURB's Avatar
Default What plugs to use for nitrous?
Just bought a tnt kit with nano, will be installing in the spring.
i know i need to switch out the plugs. I believe i was told NGK TR6 plugs are the ones i should run. What gap should i set them at?
Or is there a different, better plug out there to use?
Thanks
Aj
Note: motor is a forged 427ci.
Old Dec 20, 2009 | 07:43 PM
sprayedenali's Avatar
it all depends on what size shot you run and the tune...
i run TR6s gaped at 35-40 FWIW
Old Dec 21, 2009 | 09:55 AM
Nick@HSW's Avatar
Thanks
Aj
Depending on compression you might be a heat range 6 off the bat. We really need to know more details before anyone can recommend a plug.
Nick
Old Dec 21, 2009 | 10:01 AM
1BADBURB's Avatar
Sorry. Here are the details.
11.8:1 cr
makes 535rwhp right now n/a
heads are ported ls6.
Running reg 93 octane.
I was told to use the tr8's. What do u guys think?
Old Dec 21, 2009 | 10:16 AM
BAKED's Avatar
How big of a shot?
Old Dec 21, 2009 | 12:34 PM
1BADBURB's Avatar
Planning on a 200 shot.
Old Dec 21, 2009 | 01:39 PM
BAKED's Avatar
I'd start out with tr9's just to be safe, you will probably end up running 8's though.
