Large cam + nitrous + stock fuel system??
(190lph pump = 3,166.66667 cc per minute = 301.3 lb per hour / 8 injectors = 37.6lb)
if you're going by the common calculations everyone else goes by for how much hp that supports...
37.6lb injector * .8 duty cycle max
_______________________________ x8 injectors = 481.28hp (at the crank?)
.5 bsfc (properly tuned as you say)
if you're feeling really reckless and you want to push that ancient fuel pump past 80%... maybe 600 crank or 500rwhp. someone please correct me if i'm overlooking something.
so.. this is why i'm saying you shouldn't do it
