nitrous back fire
Old Jan 28, 2010 | 01:42 PM
gator's 99TA's Avatar
that had to get your attention!
Old Jan 28, 2010 | 03:13 PM
camscam02's Avatar
Def. sounded like it loaded up and bogged. If you had a datalogger on the car we could know for sure.
Old Jan 28, 2010 | 05:07 PM
fuel's Avatar
ok plugs look good...........i checked the compression.1 and 7 are showing compression when i was cranking the motor. #2 while cranking the motor, and the intake valve going down then going up.once up there is air rushing through the intake and out the tbody.so i guesing the valve is bent or i have a broken seat........there was some stooting stars flying out of the exhost.
Old Jan 28, 2010 | 06:21 PM
speedy55's Avatar
i was gonna say those little red bits coming out of the back used to be pretty shiney parts inside the motor. compression test will tell which cylinder is broke. you are gonna have to tear it down.
Old Jan 28, 2010 | 07:07 PM
AChotrod's Avatar
That dont look to good. Time to tear into it. Hope its not to bad.
Old Jan 29, 2010 | 05:39 PM
fuel's Avatar
ok i pulled the driver side head off and could not see any visual damage.i was wrong when i said #2.......my bad i ment the #3 cylinder wasnt making any compression.
Old Jan 30, 2010 | 05:12 PM
fuel's Avatar
here it is....
Old Jan 30, 2010 | 05:51 PM
MattxFatal's Avatar
here it is....
Damn.
Old Feb 1, 2010 | 12:04 PM
any idea what caused this?
Old Feb 1, 2010 | 12:31 PM
97blkz's Avatar
N20 maybe?
Old Feb 1, 2010 | 01:39 PM
fuel's Avatar
the mister gasket didnt like the n2o
Old Feb 1, 2010 | 01:50 PM
  #32
ATVracr's Avatar
Cometics !
Just make sure the finish on your block and heads are correct.
Old Feb 1, 2010 | 01:52 PM
  #33
ATVracr's Avatar
Detonation from a bad tune up lifted the head caused the gasket to blow.
Old Feb 1, 2010 | 07:57 PM
  #34
fuel's Avatar
im still running on the same tune...plugs have allwas looked good.....besides people blow head gaskets with a lot smaller shot then a 300
Old Feb 1, 2010 | 10:44 PM
  #35
camscam02's Avatar
Because their tuneups are not right... just because someone does it, doesnt mean it is ok for it to happen to everyone just cause...
Old Feb 2, 2010 | 04:24 AM
  #36
Robert56's Avatar
What ever caused the detonation, it was multiplied by spraying so low, IMO. The lower in the RPM band we go, the bigger chance we have of hurting parts should something go whack with the tune. Hitting a motor with a 180rwhp shot at 2900rpm is still quite an increase in cylinder pressures, besides the full 300hp is all in by .5 out. What is the RPM when the full 300 hits?
Now, the cause of the detonation? I would like to see pictures of the plugs? Might have some traces of oil on them? A big source of detonation on these motors when spraying big hits is oil getting into the cylinders. Now I say this not knowing if your running a vacuum pump, but just thought I would through it out to get the diagnostics started. I didn't see where you stated your timing, and how you were pulling it and if it was stepped. Anyway, i am sure glad it looks so far as though you didn't hurt anything major. I would have done a complete cylinder leakage test prior to tear down, and could have really helped in the overall diagnostics. Keep us apprised on what you find as the root cause of your problem.
Edit: I borrowed your video to add to my collection, hope that is OK? It's not to try and make you look bad, but rather to show that even a tune that has been previously used can cause problems should something act up. Trying to keep the street guys from running a more race like tune, where there is not much safety blanket should something go amiss.
Robert
Old Feb 2, 2010 | 08:42 PM
  #37
fuel's Avatar
Robert
not shure what the rpm is ,mabe 4500 to 5000..no problem about using the vid,its kind of a good one
Old Feb 2, 2010 | 10:12 PM
  #38
ATVracr's Avatar
Anytime we backfire the plugs come out black.
Those look like they have some oil on them also.
Old Feb 3, 2010 | 04:50 AM
  #39
Robert56's Avatar
Yes indications of oil. I was wondering if you may have old plugs that you pulled that you could snap a picture? Without the backfire we are looking for shiney black, or wet black as the the oil indicator. Or maybe go to the projected vs non-projected plug thread and look at some of the early plug pictures as they have the oil on them, then does yours ever look like this? IMO, the only way we can keep oil out of the combustion chamber on a heavily sprayed car is by going vacuum pump. Guys can use all the inline puke cans they want, even redundant, but it will not cure the oil getting into the chamber. It will help under certain conditions, a puke canned PCV system, and/or vented covers, but will not eliminate the issue of the oil getting past the rings into the chamber on the intake stroke. There is more to this story, and it gets somewhat complicated, but that is for another thread on blow-by and the LSx.
Robert
Old Feb 3, 2010 | 01:42 PM
  #40
ShiznityZ28's Avatar
Originally Posted by shortdog
Where's yours set at now? I feel a little safer with my window set at 3400 rpms.
Still set the same but the new setup leaves at 4500 rpm or so on the 2 step.
