o ring heads
Old Jan 30, 2010 | 06:15 PM
fuel's Avatar
Default o ring heads
any one know where, and how much it cost to o ring heads for a copper gasket.
Old Jan 30, 2010 | 07:43 PM
jman54002's Avatar
I use to o-ring the block, and use soild copper head gasket. I have the tool, real easy to use. just works like a rigid reamer. And then I used panio wire, .035 wire. works well. If I remember right the heads will be fited to that bore block only. but I could be wrong. The tool was pretty cheap, 150.00 or less new.
Old Jan 30, 2010 | 08:56 PM
G Engines's Avatar
Stroker Performance in orlando should be able to do that.
