School me on piston selection.....
Anywho...
The motor is going to be keeping the stock rods and crank. I have seen these units with ARP rod bolts hold PLENTY of power. The block will be .030 over of course and I plan on running a 150-200 shot. I will mainly be sticking into that nitrous area just because anything over 200 on a stock intake starts to run into distribution problems. I may possibly run a single plane down the road depending on what the motor goes into.
I do however want to bump the compression some, but still run 91 octane. And this will be using the stock heads still. I haven't thought about cam choice yet, but I do want to make sure there is enough valve relief to compensate for a high(er) lift cam.
What do you guys recommend?
The top of the piston gets pretty hot with the N2O use, so I wouldn't go too tight on the piston-to-wall or the top ring gap.
I like to polish the tops and radius all of the edges exposed to the chamber.
Exhaust valves really need the same attention due to the heat.
I'm sure you know you'll have to run a pretty cold sparkplug with a 200 shot.
A racing type non-extended plug with the larger and shorter ground strap work well because the strap won't become a glowplug and cause preignition.
