Big change
Old Mar 3, 2010 | 12:47 PM
cbr600rx7's Avatar
Default Big change
I am hoping I am on the right track with this set up and not getting in over my head. After running boost for about a year and a half I fill like its time to grow up now and move on to a more competitive set up.
I am planning to run this set up in a car that gets driven about 2 times a week as sees about 400 miles a month and might see 8-12 track days a year. My goal is to make at least 420 on motor with a RPM transmissions stage 5 4L60 with a 12 bolt. For the track I am planning to keep it very conservative for now with a LS6 manifold and single 125 shot on a 78MM ring. Down the road once i get a little bit of track time and save up a bit i want to build a duel stage ring system around a FAST 90mm intake and go for 200 with a stand alone fuel system for extra safty.
Forged 3.622 stroke x 4.030 bore
ARP Main studs
ARP Head studs
Eagle H beam rods, with ARP bolts
Stock crank
Diamond -2cc flat top pistons
Steel top nitrous rings
LS6 patriot 2.08/1.6 64cc heads
Thunder racing T Rex Cam
Double Roller Chain
almost 12.0:1 compression
110LSA with a 242/248 duration
Assembled by ( Tom - Bad LS1 )
Once again any feed back good or bad is welcome just so i can figure out if i am on the right track.
Old Mar 3, 2010 | 12:53 PM
Nitro Dave's Nitrous Outlet's Avatar
125 shot will be no problem for that combo.. Just make sure the tune up is right. Use the right plug and fuel octain. make sure you have enough fuel system.
Dave
Old Mar 3, 2010 | 01:15 PM
cbr600rx7's Avatar
Right now i am running a walbro 255 in tank and 60lb injectors other then that the fuel system is stock. I go to Ryan at RPM in NC for all my tuning.
Old Mar 3, 2010 | 01:32 PM
ATVracr's Avatar
Ryan will take care of you, just ask for the MAX effort tune up.
Old Mar 3, 2010 | 10:20 PM
cbr600rx7's Avatar
He is one hell of a tuner in my book and he stands by his work, Thats hard to find at most shops now a days.
