Is Timing Twister pulling timing?
The instructions say when the LED is flashing it is is using the pass through timing but if it is solid (which happens above 1800rpm) it says it is controlling the timing.
My first issue is why the tuner logged the same timing. My second question is if the LED being solid above 1800 rpm means it is controlling the timing then why does this happen when the system isn't even armed?
