testing solonoids with HSW Microedge
Old Mar 28, 2010 | 07:42 PM
sneaks's Avatar
Originally Posted by Whiteboy572ci
I thought if you were only using one stage you were suppose to ground the gray wire??? I though thats what it said in the instructions..
I just read the instructions again.
The TAN/LIGHTBROWN and GREY wires output a ground when the controller tells the relay/relays to go active. You connect the GREY wire if you are hooking it up to activate a second stage.
Old Mar 28, 2010 | 07:52 PM
kidcamaro98's Avatar
I just have the grey wire free hanging and everything works fine.
Old Mar 28, 2010 | 08:22 PM
Whiteboy572ci's Avatar
It felt like my system was working fine? I just ran the black and gray together and ran them both to the negative side of the battery.. I think i read it correctly, see wiring: page 1.
http://www.harrisspeedworks.com/inst...ion_Manual.pdf
Old Mar 29, 2010 | 09:48 AM
Nick@HSW's Avatar
Either will work.
Nick
