MicroEDGE Help/?'s
Old Mar 21, 2010 | 10:50 PM
Whiteboy572ci's Avatar
Default MicroEDGE Help/?'s
I have a 2001 Z06 and the wiring diagram i have and the MicroEDGE instructions have conflict each other. Its really only one im stuck on. The blue wire off the MicroEDGE says it suppose to go to a TPS/WOT switch and located at pin 24 (DK BLU) on the red connector. Pins 22-24 are not used on mine. I tried to see if there was another tps to pcm reference and nothings sticking out. The other one, not as important, i can figure out, but would help if someone knows. I will be hooking the orange wire off the MicroEDGE to the NB02 and wondered which wire off the PCM, pinout, was the signal to either b1s1 or b2s1. I believe pin 66 on the blue connector would work. PPL in color and the function is HO2S signal high b2s1. THANKS!!!!!!!!!!
Old Mar 22, 2010 | 01:22 AM
itsslow98's Avatar
probably be better off opening a ticket directly with HSW to get the best answer and support.
Old Mar 22, 2010 | 11:58 AM
rambodog's Avatar
I also believe that you can tap into the blue wire off the wire harness from the TPS itself.
Old Mar 22, 2010 | 12:26 PM
89ROC-Z's Avatar
^^ this
Old Mar 28, 2010 | 03:58 PM
Ok, i got it working. The blue wire that suppose to be at connector 24 is empty because the dk blu wire off the tps runs to a throttle actuator computer instead of the pcm. I tapped the orange to my factory narrow band, pin 66, and all is working!
Old Mar 28, 2010 | 04:46 PM
A3VETTE's Avatar
So did you tap it at the throttle actuator or put a plug in the missing pin?
Old Mar 28, 2010 | 08:38 PM
I spliced off the blue wire coming out of the tps and just ran a wire to the microedge. Looks like the throttle actuator has its own computer and omits the pins on the pcm so there plugged. Works fine, at 100% throttle it reads 4.36v and at 0% it says .96v or something..
Old Mar 28, 2010 | 08:51 PM
A3VETTE's Avatar
ok sweet
