Nitrous questions
New to the nitrous world just had some questions if somebody can help me out I have a 2000 trans am ws-6 automatic with 67000 miles mostly stock besides the air intake and did the diablo tune on it so purchased a 100 shot nos system.I got a really good deal on it thats the only reason I went that route but the guy ran it thru the gas pedal does that make sense and is there anything to worry about .Thanks and if there is anything else I need to know please explain
Sounds like a WOT switch (Wide Open Throttle). It activates the Nitrous system. You should check out the stickies on top of this Nitrous section if you haven't already. I have learned alot from them.
I would call chris @ nitrous outlet and let them help you. You just cant throw nitrous on a car without getting knowledge on how it works.
1. You need to run colder plugs
2. you need to reard your timming
3. I would upgrade your intank pump
4. I would get a nitrous controler
5 Its better to be safe and have your motor then not to have you motor.
Good luck
Good luck
Nick
