What basic nitrous kit?
Old May 3, 2010 | 11:46 PM
AR15 guy's Avatar
Default What basic nitrous kit?
Once upon a time I had a HSW kit in my lt1 z28, but I never even hooked it up.
Anyways, looking for a easy to install kit for my 02 Formula. I have considered another HSW, but I was wondering about the ZEX ls1 wet kit. The pre-wired and assembled box would make it extremely easy. I will also run a FP shut off switch and a window switch for max safety.
FWIW I want to keep it mild. Probably 100-125 tops. This is my daily driver (will be for at least a couple more years) so I need reliability and streetability.
Old May 4, 2010 | 04:25 PM
Chris@NitroDaves
Guest
Posts: n/a
IF you are looking for a basic kit then i believe this could suite your needs.
System
http://www.nitrousoutlet.com/catalog...3&product=2891
FPSS
http://www.nitrousoutlet.com/catalog...searchResult=1
Window Switch/progressive
http://www.nitrousoutlet.com/catalog...searchResult=0
N20 Gauge
All this will get you a basic system. The only other thing i could suggest would be to get a bottle heater because nitorus does run off of bottle pressure.
Heater
Old May 4, 2010 | 05:15 PM
billymz28's Avatar
I would go with the nitrous outlet plate kit and the instructions are easy to read and in color. I hooked mine up by myself and it was my first time actually easy. I would only conider 3 kits that are made nitrous outlet which I have no complaints on. Harris which seem to be real good. Nitrous express but there kits seem to be double the price for a plate kit. n20 outlet had a sale thats the main reason I chose them over harris. But after using the kit I will stay with them.
Old May 8, 2010 | 06:36 PM
dannyz's Avatar
I like my Zex wet kit.
Very easy install and set up and works just fine as long as you don't plan on shooting more then a 125-150 shot, [fwhp].
Been real reliable for me, 4 years running now.
