Tapping into Oxygen Sensor
Old May 28, 2010 | 02:27 AM
02TransAm/Batmobile's Avatar
Default Tapping into Oxygen Sensor
Last thing on my Nitrous install is tapping one of the wires from my Dynotune's Air/Fuel Lean Shutdown Switch to the oxygen sensor.
What's the best way in doing this?
Old May 28, 2010 | 11:03 AM
rambodog's Avatar
http://www.harrisspeedworks.com/inst...ion_Manual.pdf
Go to microedge install page 6 for O2 sensor wires on the website for HSW if link dosn't work.
I spliced into mine and used a wire tap along with electrical tape. You may want to use solder but its a tight area & the wires from the sensor are small diameter guage.
Old Jun 10, 2010 | 01:03 AM
Nitro Dave's Nitrous Outlet's Avatar
Get a real wideband.. The Narrow band sensor is not accurate enough to even be worth the effort..
