nitrous on stock internals
Old Jun 4, 2010 | 08:45 PM
emmanuel williamson's Avatar
Default nitrous on stock internals
I have a full bolt on 98 ss camaro and have run a best of 12.007 with a 1.60 60ft. It has a built tranny with a 4000 stall and 3.73 gears. weighs 3150 with me in it. Ok i have a lsx nitrous kit and i want to know what else i need to run my kit safely. it will be a 100 shot. And what e/t improvement do you think i will get from a 100 shot. Could it go 10s. I have alot more potential to run faster N/A the car wouldnt shift on time and there was a 20mph headwind.
Old Jun 4, 2010 | 09:09 PM
TravisMcGill2000's Avatar
pick up a 255 fuel pump and a colder plug
Old Jun 8, 2010 | 03:18 PM
Chris@NitroDaves
Guest
Posts: n/a
Things you should look into getting
Fuel pump upgrade
NGK BR7EF's ( Stock # 3346 )
FPSS - Fuel Pressure Safety Switch
Window Switch
Bottle heater
a 100hp shot should get you newhere from 1/2 a second to 3/4 of a second drop in et.
Old Jun 9, 2010 | 04:07 PM
Midnight02's Avatar
What kind of power are you making N/A? Wet or dry?
Colder plugs are a must. Should also upgrade the fuel pump. As for safety mechanisms, there are a bunch of electronic options, however a WOT switch coupled with a window switch is an effective setup. I went with the FJO Mini controller to get both of those and a progressive ramp rate on the shot to assist with traction.
Old Jun 11, 2010 | 02:57 AM
00FirebirdaREV's Avatar
Chris said it right^^^
